I am creating facade geometry of approximately 1000 faces. I use that as the input as geometry for sunhours analysis in ladybug which works but it produces like 8000 test points of sunlight hours.
I want the sunlight hours as 1 number of each panel. I then want to use that number to calculate a factor to generate and offset a second screening panel whichsize will vary according to the factor.
So question if someone can please help is can I get a single sunhour analysis for each panel?
I did that but it doesn’t give centre as a test point only on the mesh geometry but a number of test points. How does it calculate how many test points it will do for each geometry?
