The last couple of weeks since the release of Ladybug Tools for Grasshopper 1.0.0 have been exciting and, thanks in large part to the efforts of people on this forum, we wanted to issue an updated release that includes several patches for minor bugs that were identified and fixed. We also implemented a few updates to the versioning components, which we realized will make it much easier for people to jump back and forth from the stable release to the development version. In accordance with this, we have updated the download on Food4Rhino to install Ladybug Tools for Grasshopper 1.0.9 instead of the original 1.0.0.
For those who installed the new Ladybug Tools plugin over the last couple of weeks and want to get the fixes, you can upgrade by running the āLB Versionerā component with 1.0.9 plugged in for the version_ like so:
Or you could alternatively run the second component of the installer.gh currently on Food4Rhino. Also note that, after updating your installation, you can update any Grasshopper definitions that you built over the last couple of weeks by using the āLB Sync Grasshopper Fileā component.
Thanks to everyone who reported bugs over the last couple of weeks and please feel free to keep up the great work!
Restarted Rhino and I still have mostly 1.0.0 components
with few exceptions in dragonfly where I have 1.1.0 components
and a single 1.0.4 component - Versioner
I realize that itās confusing but each component has itās own version number thatās independent of the Grasshopper Plugin version number. We synced everything up for the original major release but, if you ran the versioner or the second component in the installer.gh, you have the updated installation, even though many of the components still have the 1.0.0 version number.
For the Rhino 7 issue, it seems likely that McNeel made a change in the latest Rhino 7 WIP release that broke the installation process for Rhino 7. Iāll try to investigate but I think we will need some patience with Rhino 7 given that there are still a lot of changes happening to it.
So Iām pretty sure the issue with Rhino 7 isnāt with McNeel . I just tested things on my end and itās working. But I should have made it clear that If you have just installed Rhino 7, you need to re-run the Ladybug Tools installation process using Rhino 7. Or, at the least, you need to re-run the second component in the installer and re-run the .bat file in order to set Rhino 7 to look for the Ladybug Tools core libraries in the right place.
If you get the chance, please let me know if that solves your issue @Tokarzewski.
