Are we able to install the ladybug tools folder in another file path?
@MichaelDonn and I have this installed for a group of students in shared computer spaces and the ladybug tools folder installs in the User file path which keeps changing due to multiple logins. This means we are having to fix broken file path every time we login. Are we able to change this installation file path?
There are definitely ways to do this but, if you wanted to do it using the free Food4Rhino installer, you’ll have to edit several config variables via command line. I would sooner recommend just purchasing an executable installer from us, which will allow you to select the install location when you run the installer as you see here:
You can email info@ladybug.tools to get pricing information on the executable installer.
