Hi
Is it possible for the view from sun component to accept multiple vectors (say from a single day study) and save each view as a named view? It only seems so accept a single vector and I can see anyway to save the view without doing it manually. Thanks
Hi Paul, You can’t create multiple views at the same time unless you use multiple components (one for each vector) but there is a way to create named views for each vector. Check the attached file. All you need to do is to animate the slider.
createNamedViews.gh (351 KB)
This is wonderful thank you Mostapha
Thanks Mostapha. This is great. What would be the best way to animate the slider - HoopSnake, Galapagos?
Try the LB_Fly component (it is located in section 4 of LB).
