Large radiance models: Memory errors and levels of simplifications HB-R
Hi @OlivierDambron ,
Using the new package, the command should be:
lbt-recipes run annual-daylight annual_daylight_inputs.json --workers 7
Here is the documentation for the command.
Technically, you can also run it will queenbee-local but you need to give the full path to the recipe folder instead of the recipe name. In any event, using lbt-recipes is the official way to do it.
