hi @chris
Sorry for the broken link, I think I overwrote the file while rushing.
I went for simplifying drastically the model instead of a “select all/assign/run”.
Perhaps it is worth mentioning that the geometry I was trying to use was extracted from an IFC file (using geogym plugins). Many items behaved very strangely with the HB components:
- sometimes nurbs or meshes would return the components orange/red due to invalid breps or attempts to divide by 0.
- sometimes a simple gh transformation to those geometries would make the HB Face accept it.
- when these went through the HB Face components, often the HB Visualize wasn’t showing coherent geometries with that through the Spider Rad Viewer. Although this is a different issue, I just thought I’d mention it as all of the fuss I made could very well be due to inappropriate geometry extracted from an IFC file.
The two hbpkl components work on my end. Thank you, this will definitely help with heavy cases.
I look forward to the commands accepting hbpkl it.
As a side note, I noticed after updating that the HB Run Recipe component disappeared from the ghtab:
Do you have the same?
Olivier
