LB Adaptive Comfort "No Attribute" Error
Hi @chris or someone else knowledgable, my team is running into this issue with the LB Adaptive Comfort component in LB 1.8, 1.3, 1.8.1 in R7 and R8. Any ideas on why this may be?
It was working for some of our team members before they installed 1.8.
  1. Solution exception:‘AdaptiveParameter’ object has no attribute ‘ashrae55_or_en15251’
Thank you for reporting this issue, @remyweather .
It was a bug that was introduced when we added support for the new EN-16798 standard back in June of this year. It only affected the case where you plug in numbers to the LB Adaptive Comfort component without any data collections.
I just pushed a fix here:
… and you should now be able to get it with the LB Versioner component.
Thanks again!
Incredible, thanks so much @chris Chris for the lightning speed fix!
