LB Create Legend – Some Edits (UPDATE)
:green_circle: Ladybug “Create Legend” Multi-Viewport Modified
(See demo video at the end)
Follow-up to the previous post, with improvements on viewport handling and rendering behavior. Again, these modifications were mainly made for my own work presentations and data visualization outputs. Just mentioning @chris here — this is more of an experimental tweak for reference.
In the original LB Create Legend component, legend generation relies on
VisualizationSetConverter.convert_legend2d() which depends on ActiveView.
This design leads to several practical limitations:
  • When multiple Rhino viewports are open, the legend aligns only with the ActiveView,
    often causing incorrect scaling or misalignment in other viewports.
  • It’s not possible to specify which viewports should display the legend.
  • When a viewport is maximized or minimized, the legend does not automatically realign or resize.
  • When the component is disabled, the legend remains visible on the screen.
:wrench: Modification
To address these issues, this modified version introduces the following updates:
  • :white_check_mark: Use args.Viewport – The drawing logic now references the viewport passed through DrawViewportWires instead of relying on ActiveView, ensuring correct alignment within each active display context.
  • :white_check_mark: Automatic Size Synchronization – The legend automatically rebuilds when a viewport changes size (e.g., maximize or minimize).
  • :white_check_mark: Add viewport_ Input – Allows users to specify which viewports the legend should appear in.
  • :white_check_mark: Disable Handling – When the component is disabled, drawing is automatically stopped to prevent residual legends.
:puzzle_piece: Implementation
This version makes no modifications to external Ladybug files (e.g., preview.py).
Instead, it extracts the essential legend-generation logic and rewrites it as an internal utility function, serving as an experimental embedded version for multi-viewport support and testing.
Original:
Modified:
Script:
# ✅ Utility function: Generate a legend sprite based on the specified viewport
def convert_legend2d_JT(legend, viewport):
    Convert Ladybug legend to 2D bitmap sprite using a specific viewport,
    avoiding dependency on ActiveView.
    # LB Original: Module imports (same as original)
    import System
    import Rhino.Display as rd
    import Rhino.Geometry as rg
    from ladybug_rhino.color import color_to_color, black
    try:
        # ✔ Modified: Use the given viewport size instead of ActiveView
        v_size = viewport.Size
        vw, vh = int(v_size.Width), int(v_size.Height)
        # LB Original: Generate color matrix from legend
        color_mtx = legend.color_map_2d(vw, vh)
        color_mtx = [[color_to_color(c) for c in row] for row in color_mtx]
        # LB Original: Convert color matrix to .NET Bitmap
        net_bm = System.Drawing.Bitmap(len(color_mtx[0]), len(color_mtx))
        for y, row in enumerate(color_mtx):
            for x, col in enumerate(row):
                net_bm.SetPixel(x, y, col)
        rh_bm = rd.DisplayBitmap(net_bm)
        # LB Original: Calculate legend pixel dimensions
        l_par = legend.legend_parameters
        or_x, or_y, sh, sw, th = legend._pixel_dims_2d(vw, vh)
        s_count = l_par.segment_count
        s_count = s_count - 1 if l_par.continuous_legend else s_count
        leg_width = sw if l_par.vertical else sw * s_count
        leg_height = sh if not l_par.vertical else sh * s_count
        cent_pt = rg.Point2d(or_x + leg_width / 2, or_y + leg_height / 2)
        draw_sprite = (rh_bm, cent_pt, leg_width, leg_height)
        # LB Original: Generate 2D text (labels + title)
        _height = legend.parse_dim_2d(l_par.text_height_2d, vh)
        _font = l_par.font
        txt_pts = legend.segment_text_location_2d(vw, vh)
        cent_txt = False if l_par.vertical else True
        draw_2d_text = [
            (txt, black(), rg.Point2d(loc.x, loc.y), cent_txt, _height, _font)
            for txt, loc in zip(legend.segment_text, txt_pts)
        t_pt = legend.title_location_2d(vw, vh)
        draw_2d_text.insert(
            0, (legend.title, black(), rg.Point2d(t_pt.x, t_pt.y), False, _height, _font)
        # LB Original: Return sprite and 2D text
        return draw_sprite, draw_2d_text
    except Exception:
        # ✔ Modified: Original raises an error or returns None on failure.
        #   Here we safely return (None, [])
        return None, []
# ✅ Main class: Create Ladybug Legend (2D / 3D)
class MyComponent(component):
    # ✔ Modified: Added extra state attributes to support multi-viewport and sprite caching
    def __init__(self):
        super(MyComponent, self).__init__()
        self.draw_2d_text = None
        self.draw_sprite = None
        self.colored_mesh = None
        self._legend_for_sprite = None  # Temporarily store legend for sprite regeneration
        self._vp_size_prev = (0, 0)     # Record last viewport size to avoid rebuilding every frame
        self.viewport = ()              # Default empty tuple = all viewports
    # ✔ Modified: RunScript adds viewport_ parameter and reorganizes structure
    def RunScript(self, _values, _base_plane_, title_, legend_par_, leg_par2d_, viewport_):
        # LB Original: Component metadata
        ghenv.Component.Name = "LB Create Legend"
        ghenv.Component.NickName = 'CreateLegend'
        ghenv.Component.Message = '1.9.0'
        ghenv.Component.Category = 'Ladybug'
        ghenv.Component.SubCategory = '4 :: Extra'
        ghenv.Component.AdditionalHelpFromDocStrings = '0'
        try:
            from ladybug.legend import Legend, LegendParameters
        except ImportError as e:
            raise ImportError('\nFailed to import ladybug:\n\t{}'.format(e))
        try:
            from ladybug_rhino.togeometry import to_plane
            from ladybug_rhino.fromobjects import legend_objects
            from ladybug_rhino.grasshopper import all_required_inputs
            raise ImportError('\nFailed to import ladybug_rhino:\n\t{}'.format(e))
        # ✅ STEP 1: Validate inputs and build legend
        # LB Original: all_required_inputs + create LegendParameters
        if all_required_inputs(ghenv.Component):
            legend_par_ = legend_par_.duplicate() if legend_par_ is not None else LegendParameters()
            if _base_plane_:
                legend_par_.base_plane = to_plane(_base_plane_)
            legend_par_.title = title_
            # Create Legend
            # LB Original: Create legend and compute colors, labels
            values = []
            for val in _values:
                try:
                    values.append(float(val))
                except AttributeError:
                    values.extend(val.values)
            legend = Legend(values, legend_par_)
            colors = [color_to_color(col) for col in legend.value_colors]
            label_text = legend.segment_text
            # 3D / 2D mode branch
            # LB Original: Branching based on leg_par2d_
            if leg_par2d_ is None:
                # --- 3D Mode ---
                self.draw_2d_text, self.draw_sprite = None, None
                rhino_objs = legend_objects(legend)
                mesh, title_obj, label_objs = rhino_objs[0], rhino_objs[1], rhino_objs[2:]
            else:
                # --- 2D Mode ---
                mesh, title_obj, label_objs = None, None, None
                legend.legend_parameters.properties_2d = leg_par2d_
                # ✔ Modified: Do not immediately create sprite; store legend for DVW dynamic generation
                self._legend_for_sprite = legend
        else:
            # LB Original: Reset outputs when inputs incomplete
            mesh, title_obj, label_objs, label_text, colors = None, None, None, None, None
            # ✔ Modified: Clear viewport state
            self.viewport = ()
        # ✅ STEP 2: Handle viewport input
        # ✔ Modified: Added viewport_ input logic to support multi-viewport filtering
        if viewport_:
            if isinstance(viewport_, (list, tuple)):
                self.viewport = tuple(str(vp).strip() for vp in viewport_ if vp)
            else:
                self.viewport = (str(viewport_).strip(),)
        else:
            self.viewport = ()
        # ✅ STEP 3: Update state
        # LB Original: Save mesh as colored_mesh and return
        self.colored_mesh = mesh
        return (mesh, title_obj, label_objs, label_text, colors)
    # ✔ Modified: Fully rewritten DrawViewportMeshes for multi-viewport support,
    # dynamic sprite generation, and scale handling
    def DrawViewportMeshes(self, args):
        try:
            if ghenv.Component.Locked:
                return
            display = args.Display
            # ✅ STEP 0: Dynamically rebuild sprite and text for each viewport in DVW
            # ✔ Modified: Added safety check — return early if legend not available
            if not self._legend_for_sprite:
                return
            # ✔ Modified: Compare current vs previous viewport size to avoid unnecessary rebuild
            vw, vh = float(args.Viewport.Size.Width), float(args.Viewport.Size.Height)
            if getattr(self, "_vp_size_prev", None) != (vw, vh):
                self._vp_size_prev = (vw, vh)
                try:
                    # ✔ Use custom convert_legend2d_JT() instead of LB internal version
                    d_sprite, draw_list = convert_legend2d_JT(self._legend_for_sprite, args.Viewport)
                    self.draw_sprite, self.draw_2d_text = [], []
                    # sprite
                    if d_sprite and len(d_sprite) == 4:
                        img, pt, w, h = d_sprite
                        self.draw_sprite.append((img, pt.X / vw, pt.Y / vh, w, h, vw, vh))
                    # text
                    for (text, color, pt, justification, size, font) in draw_list:
                        self.draw_2d_text.append({
                            "text": text,
                            "color": color,
                            "rx": pt.X / vw,
                            "ry": pt.Y / vh,
                            "justification": justification,
                            "size": size,
                            "font": font,
                            "ref_vh": vh
                    import System.Diagnostics
                    System.Diagnostics.Debug.WriteLine(
                        "[JT] Sprite & Text rebuilt for viewport '{}', size=({}, {})".format(
                            args.Viewport.Name, int(vw), int(vh)
                except Exception as e:
                    System.Diagnostics.Debug.WriteLine("Sprite rebuild failed: {}".format(e))
            # ✅ STEP 1: Check display condition
            # ✔ Modified: Added multi-viewport filtering via self.viewport
            if not self.viewport:
                # No input → show in all viewports
                allow = True
            else:
                # Only show in specified viewports
                allow = args.Viewport.Name.lower() in [v.lower() for v in self.viewport]
            # ✅ STEP 2: Perform drawing
            if allow:
                # LB Original: Draw 3D mesh
                if self.colored_mesh is not None:
                    display.DrawMeshFalseColors(self.colored_mesh)
                # ✔ Modified: Draw2dText now scales dynamically based on viewport ratio
                if self.draw_2d_text is not None and len(self.draw_2d_text) > 0:
                    # Precompute ratio to avoid repetitive division
                    scale_ratio = vh / float(self.draw_2d_text[0]["ref_vh"])
                    for entry in self.draw_2d_text:
                        pt_px = rg.Point2d(int(entry["rx"] * vw), int(entry["ry"] * vh))
                        dyn_size = int(entry["size"] * scale_ratio)
                        display.Draw2dText(entry["text"], entry["color"], pt_px,
                                           entry["justification"], dyn_size, entry["font"])
                # ✔ Modified: Draw sprite with proportional scaling
                if self.draw_sprite is not None:
                    for sprite in self.draw_sprite:
                        if len(sprite) == 7:
                            img, rx, ry, w, h, ref_w, ref_h = sprite
                            pt_px = rg.Point2d(int(rx * vw), int(ry * vh))
                            scale_factor = vw / ref_w
                            display.DrawSprite(img, pt_px, int(w * scale_factor), int(h * scale_factor))
                        else:
                            display.DrawSprite(*sprite)
            System.Windows.Forms.MessageBox.Show(str(e), "script error")
    # LB Original: Keep get_ClippingBox definition unchanged
    def get_ClippingBox(self):
        return Rhino.Geometry.BoundingBox()
This is really cool, @tutu7931 !
Sorry that I missed seeing this months ago. I gave your code a try and it works but I have not been able to get it quite as stable as it looks in your video. There’s some sequence of events I did that have caused the legend to get stuck in both 2D and 3D mode:
But I really like the idea here. Are you interested in contributing this (or some of this) to the official code base?
If so, I’m happy to help test or work with you to make (at least some of) these features official. At a minimum, a viewport_ input to this component sounds really useful to prevent the 2D legend from displaying in multiple viewports.
It’s possible that some of the instability that I am expereincing results from me not pasting your code correctly into the component that I have here on my system (the import statements in my component may need to be better organized). So, if you a .gh definition with your component in it that you are willing to upload, I’ll happily test that.
Again, very cool and good work!
Hi @chris,
Appreciate the reply — I assume it’s been a busy time for you.
In the meantime, I’ve been quite deep into Butterfly and OpenFOAM lately. Regarding the Legend component, I think I might have a newer version somewhere on canvas that is more efficient and stable.
I’d be more than happy to share the code. Once I wrap up what I’m currently working on, I’ll upload it — although I still think there’s room for improvement, I just haven’t had much time to continue refining it lately.
Hey @tutu7931 ,
I am just letting you know that I added a viewport_ input to the LB Create Legend component, which is similar to what you showed in your video:
However, I made this input consistent with how it works on the other components right now that have a viewport_ input (namely, LB Preview VisualizationSet and LB Screen Oriented Text). So I did not implement any of the more sophisticated acrobatics that you were performing as the size of the viewport changed (we can always do those later if we can find a way to get it stable). But the new component can accept multiple viewports and will only render to those viewports.
Hopefully, this at least unblocks the people who want to use this component with parametric simulations and they only want the legend to show up in one of the viewports that they are screen-shooting with each parametric iteration.
