LB Generate Point grid (GenPts) rotates grid
Hello Ladybug community,
i occured at sligt problem with my GenPts component. one of my grids seems to rotate itself with a 45 degrees (blue marked area), an can’t really figure out why it does so.
I’ve linked the rhino file and grasshopper script. Anyone occured upon the same problem?
Grasshopper_genpts rotation og grid.gh (17.2 KB)
Rhino_Genpts rotation og grid.3dm (72.3 KB)
Update:
If i connect the edges directly into the PolyOffset, the grid structure change between the surfaces:
Stil don’t know why though…
Hi @LasseF,
Here’s a solution for you that uses the guidance “FOR ADVANCED USERS”
Grasshopper_genpts rotation og grid - CB Edit.gh (25.2 KB)
Hope that helps
Cheers,
Charlie
Thank you charlie!
Somehow if i utilize this method all over my other floors (which is not a par tof my uploaded files) it rotates the grid, like the about wrong shown (non linear to form).
though, i just don’t apply this to those floors. don’t really understand why i works on one form, but not the other…
But for now i solves my problem. so a big THANK YOU charlie :partying_face:
