Hi Ladybug team,
I have a question, the mesh generated by LB generate point grid mesh has no vector assigned to the faces in the rhino mesh it self. How can I assign the normal to the rhino mesh? It is causing problems sometimes when I combine LB workflow with my custom scripts. Also, when I want to display the normal I get to have displaying problems
It is showing black
instead of this
Thank you for your help
