Hi fellow nerds.
I have come onto an issue these last few weeks. The last couple of times I have opened GH, all of the Ladybug and Honeybee components have been removed from the ribbon, however, the panels still appear!
The wired thing is that I can still call on all of the LB/HB components, double-clicking the canvas. My old scripts also still work fine.
(However, as I am still rookie to LB/HB, I’d like to access the components the old-fashioned)
My other custom packages and GH native componets are there just as normal. (However, I have never actually used these)
I use custom layout, hiding some packages I don’t need right now.
I’ve tried to uninstall LB+HB using the Remove Ladybug+Honeybee script and reimport all of the components. Nothing happens.
However, the component files are removed from the folder i drag-n-dropped them from (don’t know if that is normal procedure).
I hope you guys can help me here.
GH:
Explore (The components are gone after importing/drag-n-drop’ing them to GH canvas):
Regarding the uninstall file. It includes a ‘RemoveHB’ component and a toggle to set to True here. It does, however, also include another small script that requires file addresses. Is this important for the uninstallation?
- Lasse
