on the previous versions of LB Humidity metrics there were results for the Partial and Saturation Pressure as outputs.
How can I reach these values also in 1.3.0? Thank you!
Hey @destefano ,
I don’t know exactly what previous version you are referring to but you can request any output that you want from EnergyPlus by using the Custom Simulation Output. Then, you can parse those results into Grasshopper using the Read Custom Result component. So you can use those to request the partial and saturation pressures. FYI, you can use the Read Result Dictionary component to get a list of all the EnergyPlus outputs that you can request from a given simulation.
