Hello everyone, I just started using lb.
I need to use radiation analysis to get the solar radiation received by the ground and the building surfaces in a limited area for each hour of a day. For example, I want to know how much radiation falls on the ground within those buildings at 11:00 on September 18
But I am confused by the hourly result, it shows that from 18 SEP 11:00 to 12:00 the max radiation on the ground is 1.18 KWh/m^2, which means the average radiation in this hour is about 1.18KW/m^2?
But the epw file shows that even the global radiation is 828Wh/m^2 at 11:00 ,851 Wh/m^2 at 12:00, so is there anything wrong or I have some misunderstanding?
By the way, I test a model with only one ground surface(no context), it also shows the same maximum 1.34 KWh/m^2 result
So those are my question, I would appreciate if someone can answers me:
CHN_Guangdong.Guangzhou.592870_IWEC.zip (217.6 KB)
I have uploaded my epw file ,and I wonder whether my setting counts as 2 hours cumulative amount (11:00,12:00),so the results need to be divided by 2? If we do that the results seem more reasonable.
