Hey,
after updating to LBT 1.6 the LB Spatial Heatmap component with the LB versioner is always showing an error when placed on the canvas. It might be a bug in the code.
What do you think?
Hi @Matteo ,
I think this is a bug that we accidentally introduced 3 days ago. I am working on a fix now. Using the LB Versioner component to go back to version 1.6.71 should fix the issue for now.
FYI, @Matteo ,
The fix is now officially merged in the code base and you can get it with the LB Versioner without having to go back a couple of versions.
