hai, im having this issue
here was the script
The run on the component before is set to false. Thus there is no data available from that component.
but when it set the to true, in the end the result was 0, should i run the annual daylight script first then at the end run the spatial heatmap?
Hi @marvel,
Are you able to share the Grasshopper file? Remember to internalize the geometry or attach the Rhino file as well.
