Hello
I am trying to visualize Annual Glare results with LB Spatial Heatmap and its error is 1. Solution exception: Expected the number of data set values (533) to align with the number of faces (612) or the number of vertices (714).
do you know what’s wrong with it?
Hi @elnazbrd there is an example file for annual glare with spatial heatmap that can be found here incase you want a reference file.
hopefully that is helpful.
I tried this way but still have the same error.
