Hi all.
I noticed a strange behavior with this component. It seams that the legend txt as well as the degrees of the sunpath component when used within a file in meters It outputs an out of scale title mesh. As soon as the scale is changed again to millimeters the legend works fine. I’ve always thought that all the analysis done in LB and HB should be in meters.
Is anybody else having this problem?
Thank you
cheers
