hi guys,
Does anyone encounter the multitple windroses issue when assigning them conditional statements ? The component works only when not inputting conditional statement…
Multiwindroses.gh (85.0 KB)
Cannot manage to make this work … helpsss
@mostapha you didn’t talk about data tree issue in your windrose demonstration video ?
Charles C.
Actually it works.
Your uploaded file has 4 issues:
- the analysis period, as you defined them, using the data component, fail to act. Using the “real” analysisPeriod component makes it work.
- The maxFrequency_ you set is fine for the winter season, but for the summer the resulting geometry is too small.
- You need to define some condition for the whole year case. Leaving the condition blank/empty doesn’t yield any result.
- You were also missing to insert the LB_LB component.
Hi Abraham,
My apologies for the late answer. Thank for pointing out the data component issue ! Although, usualy leaving the conditions blank for the whole year usually work with the windrose component… What conditions should I input to get ALL of the winds ?
I give this definition a try 1 week ago and it still didn’t work…
Can you upload your working definition
Thanks alot !
-Charles C.
Leaving the conditional empty doesn’t fail the analysis. True.
For what i see in your example, this doesn’t affect the result when applied alone.
For some reason used with the Entwine changes them a bit.
In any case your conditions yield that almost no winds can stand by them. See image below. You need a very close zoom to see.
Have to say that i used my local epw and not yours, so it may change for you.
Multiwindroses_AY.gh (458.6 KB)
