Hi, it’s exciting to try all the radiance-related functions of legacy in LBT 1.3!
But when I tried the EXAMPLE FILE called “gridbased” (think I don’t need to upload this file again?) within the honeybee-radiance folder downloaded with the installer, , I had a problem as it shows:
Runtime error (PythonException): The recipe failed to run with the following summary:
Scheduled 7 tasks of which:
2 ran successfully:
1 CreateRadFolder(…)
1 GenerateSky(…)
1 failed:
1 AdjustSky(…)
4 were left pending, among these:
4 had failed dependencies:
1 CreateOctree(…)
1 LetPointInTimeGridFly(…)
1 PointInTimeGridRayTracing(…)
1 _Main_89d38f18Orchestrator(…)
This progress looks because there were failed tasks
Use the report_out attribute of recipe settings to see a full report.
Traceback:
line 96, in script
I have updated my RADIANCE version per the recommendation. Does anyone know how to resolve it?
Thank you in advance!
That will allow us to see the exact error (the same as you would see with the report_out attribute that the error message suggests). Then, I can know exactly what went wrong and we can push a fix.
Yep! It’s the whitespace. Give me through today to push a fix for this. In the meantime, you might be able to get the recipe to run by plugging in a folder_ with no white spaces into the HB Recipe Settings component and assigning those settings to the recipe.
Ok, i just merged a fix into the development version of the plugin:
@tiffiena , if you would not mind running the LB Versioner, restarting Rhino, and then try running the grid-based recipe again, it would be good to have confirmation that everything is fixed now.
This is a big enough issue that I am going to update the installer.gh that comes with Food4Rhino. If you let me know that things are fixed before the end of the day, I’ll update the installer sooner than later. Otherwise, I’ll just update it tomorrow.
Thank you, @AbrahamYezioro and @tiffiena ,
I just updated the installer.gh on Food4Rhino to include the new fix. I’m glad that we were able to patch this one and I’m sure you helped a lot of people here.
Hi everyone! I faced the same initial problem of @tiffiena but I don’t seem to figure out how to fix it. I followed your suggestion and updated everything. Now I have the 1.5 version.
