LBT 1.4- Split floor to thermal zones
Hi @AbrahamYezioro
That was so helpful. Thank you so much.
Is there a way to define air walls with their thermal properties? Currently, I have been trying to compare the energy results of a simple box with the same geometry divided by the air walls. However, the energy results are not close to each other:
So, I was wondering if I could define the air walls by custom.
