Testing the Point in Time (PIT) recipe the Climate Based sky fails, complaining about:
Runtime error (FileNotFoundException): Could not find file ‘C:\WorkingFolder\Courses\Simulations\04_LightRights\2021_LR\BoxSimulations\point_in_time_grid\results\Model_3_Room.res’.
Traceback:
line 41, in read_sensor_grid_result, “C:\Users\USERNAME\ladybug_tools\python\Lib\site-packages\pollination_handlers\outputs\helper.py”
line 15, in read_pit_from_folder, “C:\Users\USERNAME\ladybug_tools\python\Lib\site-packages\pollination_handlers\outputs\daylight.py”
line 517, in value, “C:\Users\USERNAME\ladybug_tools\python\Lib\site-packages\lbt_recipes\recipe.py”
line 314, in output_value_by_name, “C:\Users\USERNAME\ladybug_tools\python\Lib\site-packages\lbt_recipes\recipe.py”
line 91, in script
Thanks for reporting, @AbrahamYezioro . This one might be a question for @mostapha or someone who knows Radiance better than I do. For some reason, Radiance is failing to run the following climate based sky string through the CreateOctree function, which I can see is essentially running the Radiance oncov command:
Ah, I should clarify that, while things will run to completion with what I pushed yesterday, the solar irradiance results will not be perfectly correct until you run the versioner again to get the fix that I just merged now:
The illuminance from yesterday should be correct, though. In any event, once you get the latest fix, all of your point-in-time results should match Legacy and the older Honeybee[+] almost exactly (bearing in mind the stochastic behavior of Radiance).
