Hi, The soon I add a number to x scale, the legends disappear. How to manage to keep it in 3d but in the same time view the legends. Thank you
I think this is a minor bug from rhino 6 that happen to perspective, check top view.
not either in top view. I have realized its only for drybulbtemp!! because the legend appears perfect in relative humidity !!!
I just found it. It is the rendered view that causing the issue. some works in rendered and some don’t. Thank you @Nariman.Rafati
try this, make a clipping plane above the 3D chart in perspective view, this works
