Life-cycle cost analysis (LCCA) is a tool to determine the most cost-effective option among different competing alternatives to purchase, own, operate, maintain and, finally, dispose of an object or process, when each is equally appropriate to be implemented on technical grounds.
Good question. There was just a performance network on this but it wasn’t part of the ladybug tool set. I’ve yet to watch the video. This is one thing that Sefaira makes very easy to see with its performance/cost charts.
The main problem is, as Mostapha said, there is really not enough open data to accomplish this.
Most of the times someone does get such data they are not so inclined to share.
However, if you have estimates for the products, materials, and constructions you are using in your model you can easily add the LCCA part on top of it with native GH components. I’ve done a few of those (rudimentary) models myself.
Everybody has pretty much made the point already but I just wanted to add that the LCCAs that we do in my office typically take a month or so to assemble primarily because we need a cost estimator to make an inference about the initial cost of materials and labor of construction. These quantities vary substantially across different locations and time periods so I would not trust any source that argues for one universal cost value of given material for all projects. I will say that quantifying energy cost savings is pretty straightforward with Honeybee and you can see an example here:
