Hi, I was trying to simulate the effects of light tube using the script from https://github.com/sariths/honeybee/blob/3fb53721c62da99bdea180add75edde15d351020/testPmap.py. It uses the Photo Map method. However, the GHPython Script component returned an error of ‘1. Solution exception:cannot import radiance from honeybee’. Would like to know if there is an ‘easier’ way of simulating light tube instead of using Three Phase/ Five Phase since I am not familiar with the command line method.
Thank you.
