I have spent an hour canvassing the discourse for any discussion on this topic but unable to see anything. Could anyone clarify why the ‘Line Chart’ component in the Ladybug legacy versions did not find its way into the new 1.3.0 version? I really found this line chart of great use when trying to look at multiple data sources over a single small period (a day/week) to identify correlation/causation. And on using v1.3.0 I see that this is not possible using the Monthly Chart component which requires a full annual data source to populate.
@chris 's Visualise peak loads hydra file demonstrates this capability, which I’m not sure is achievable in v.1. Hydra Viewer
Has anyone reached a workaround to generate a line chart of a smaller subset of data to do this?
