Load Balance values
Hi everyone. I’m coding a simple box model of a building located in climate zone 5.
While running the load balance the Mechanical Ventilation and storage value is waay higher than expected. Leaving no room for improvement in envelope, I thought there might be something wrong with my materials but I set up baseline values and the behavior is the same.
20210630 - loadsbalance.gh (824.4 KB)
@CarlosKellyGro ,
It seems like this issue is happening because you used a multiplier for the Rooms, which is causing the cooling/heating to be 11 times larger than it should be. Let me investigate and push a fix but, in the meantime, removing the Room multiplier should make your energy balance correct.
I just pushed a fix to the development version of the LBT plugin and you should be able to get it on your end with the “LB Versioner” in an hour or so:
Thanks again for reporting!
