The solution follows from looking at Problems of reading existed sql files. Inside of the .gh file you will find an example of individual .sql files being read into the RoomEnergyResults component. To formulate the list for a ton of buildings at one time, there is no consolidated location. Copy the folder paths for all of the buildings then add eplusout.sql to each path. A text editor is helpful for this.
