Testing the new dump/loaddata components i see that the CSV load is giving a Null output. The other two (json and pkl) work fine.
Thanks @AbrahamYezioro ,
Your track record for testing things in the first 24 hours that they’re released is impressive!
It seems like I had just forgotten to push the changes that I had on my local machine. I just added them here:
… and you should be able to get them with the LB Versioner in an hour or so. I verified that, once you have these changes installed, everything works as intended:
Thanks @chris!!
Glad to check at release time … for me is a challenge.
This component is a very good one!!!
