I’m having issues with the vector based shadow study I downloaded from hydra:
location component not being read correctly - any ideas?
have tried inputting directly from epw file, writing manually like in above. Cannot get it to work.
You are mixing LB Legacy with LBT. They don’t like each other much. Use the sunpath
from LBT and you’ll be set.
