LockFileEx error from HB End Use Intensity
The new EUI component in version 1.2.0 gives me the following error in Rhino 6 on Mac:
Solution exception:LockFileEx assembly:<unknown assembly> type:<unknown type> member:(null)
At first glance, this appears to be the same issue dealing with reading SQLite files that @chris dealt with last summer. However, other components that read SQLite files (such as HB Read Room Energy Result) seem to be working fine.
I first encountered this error while playing with the show_box_energy_model sample script, but have reproduced it in my own scripts as well.
@coditect ,
You are correct that it’s the same issue and I’ll have to implement a similar workaround for that component. I opened an issue for it and I’ll try to push a fix soon:
@chris,
I submitted a potential fix for this issue via Github pull request. Since I’m not familiar with your build process, I tested the code by copying it into a GHPython component in Grasshopper. The numbers it produced look reasonable, but I don’t have access to a Windows machine at this particular moment to compare results.
Please let me know if it looks reasonable — I would like to be able to contribute to Ladybug in the future.
The changes to honeybee-energy were made available through LB Versioner a few days ago, but the modified EUI component has not. What is the timetable for patch releases to honeybee-grasshopper-energy to make their way out?
Ah, that’s my fault. It’s because we didn’t merge your PR here using a semantic release tag like fix(result):. So your improvement hasn’t gotten released yet. I will trigger another shortly, which will ensure that you can get it with the LB Versioner. I’ll post back here once it’s available.
You can now get your updated version of the component with the “LB Versioner”, @coditect . Thank you, again, for fixing this issue and for improving the energy-use-intensity command !
@chris, thanks for pointing me in the right direction!
