natchan
1
Hi.
The error about “LookupFolder_Daylighting” component was appeared.
I set a folder(C:\Grasshopper\study\test) to the working directory.
And I found the files in the folder I defined like the image.
Why cannot clear this error message?
Thank you.
Natchan,
You need to reinsert both HB_runDaylightAnalysis and HB_LookupFolder_Daylighting assuming you updated from the github.
Both of them have changed in the number of input/output items.
I’m sure that will fix the issue.
natchan
3
Hi, Abraham.
I reinsert the components,and the error was vanished.
thank you for your kind.
