Hi, since the last time I used the solar envelope component the output has changes from brep to mesh, which makes it hard to make the geometry solid for 3D print etc.
Does anyone have a solution for extruding the output mesh down to the base geometry to make it a solid?
And out of couriosity, why has it been changes for the worse in the later versions??
Thanks!
