Due to company policies I have had struggles updating ladybug[+] and honeybee[+] with the supplied install.gh script.
Quick Fix
Use the attached installer-FIX.gh (14.4 KB). It will do the magic for you, alternatively do the steps below.
Original output:
The error message writes the following:
Downloading ladybug the github repository to C:\Users\mathias.nielsen\AppData\Roaming\McNeel\Rhinoceros\5.0\scriptsRuntime error (PythonException): SystemError(‘The request was aborted: Could not create SSL/TLS secure channel.’,)
Download failed! Try to download and unzip the file manually form:
https://github.com/ladybug-tools/ladybug/archive/master.zip
Traceback:
line 78, in updateHoneybee, “”
line 157, in script
And if you download the above mentioned zip it doesnt reveal where to put it. Nor does it reveal that it needs three more downloads.
Manual Fix
By fiddling a little with the code I found out that a user has to download these four links:
https://github.com/ladybug-tools/ladybug-grasshopper/archive/master.zip
https://github.com/ladybug-tools/honeybee/archive/master.zip
https://github.com/ladybug-tools/honeybee-grasshopper/archive/master.zip
and the content should be unzipped here:
C:\Users<USER NAME>\AppData\Roaming\McNeel\Rhinoceros\5.0\scripts
Hope this helps if anyone else has installation issues!
Tags:
Honeybeeplus HBplus HB[+] installation firewall SSL install server
