Hello, I’m currently working on Honeybee and I’m pretty new to it. I did simple box houses and used video tutorial that worked properly. But now I’m working on a school project with an actual example house that I modeled in Rhino and even though this is still the beginning of the GH definition - it has errors…
I wanted to attach the rhino and GH files - they are simply a house model and a GH definition including only a brep of closed objects and a Mass2Zone component that doesn’t want to work - but since I’m a new user I can’t so I will put a link to download them online… I tried to intersect the masses but this doesn’t work as well and I don’t understand why.
The solutions that I tried so far:
- redoing the geometry a few times to make sure everything is closed and next to each other.
- after finding a similar question here and the person fixed it by updating ladybug and honeybee - did that as well.
Result is so far the same… Hope someone can help me
LINK: https://we.tl/t-oj0pgbo4fw
PS: In the rhino model for the GH definition I only use the TEST layer!
