Hi, I try to add Custom material RoofVegetation
(text IDF example, that I’ve found here Group – Surface Construction Elements: Input Output Reference — EnergyPlus 9.4 )
in version 1.1.0 to - …ladybug_tools\resources\standards\honeybee_standards\constructions
but it doesn’t work. I’ve tried to add it as Idf file et as Json file. I’d just saved a text in text editor in idf/json format.
If I understand well in version 1.1.0 I have to do json file for material? Where could I find which format I need to do for custom material json file? Or which way I can do new json for HB? If I understand well in IDF example in link I have all necessary data for RoofVegetation material.
Hi again,
I’ve created a Json file for Material:RoofVegetation, but it gives me an error : Solution exception : expecting object : line 10, column 14, char 247. Could you have a look at the file please?
If I am not mistaken: currently Material:RoofVegetation is not currently supported in the Honeybee-Energy Code at the moment, to simulate with that IDD object I think you could use an open studio measure to ‘swap’ or add to whatever construction you want to use the Mat:RoofVeg with.
I am currently encountering the same issue regarding importing (adding) RoofVegetation to LBT version 1.4.0.
I imported “Grassy Lawn” formatted as per GitHub Link 1 and GitHub Link 2 in the following file directories:
ladybug_tools\resources\standards\honeybee_energy_standards\constructions\opaque_material.json
ladybug_tools\resources\standards\honeybee_energy_standards\constructions\opaque_construction.json
Still, in Grasshopper I get the issue: “EnergyMaterialVegetation is not a recognised Energy Material type”.
How can I import EnergyMaterialVegetation as a possible material type like in the following test .py file on GitHub?
Just run the LB Versioner and restart Rhino. This will update you to the latest development version of the LBT-Grasshopper plugin, which has full support for vegetation materials. No need to edit any source code files.
