I use Rhino7; however, I install Energyplus 23.1 and OpenStudio 3.6.1. for other uses. When I check the versions in Honeybee, I see that Rhino detects EnergyPlus 23.1 and OpenStudio 3.6.1.directly and starts to use it. Even if Rhino7 matches with OpenStudio 3.5.0 in the compatibility matrix, I got results with OpenStudio 3.6.1. However, I am not sure if the results are correct or not.
May I continue to use OpenStudio 3.6.1. and EnergyPlus 23.1 with Rhino 7 and get energy simulation results correctly in Honeybee?
