Measuring units of the Radiation Analysis outputs
This is a reply to a questions from Jacob (and Abraham):
…****which measuring unit does your radiation component output?
There are two different outputs that has two different measuring units:
radiationResult is the amount of radiation for each test point in [kWh/m2]
Note: each test point is the center of a mesh face and the number represents the amount of radiation per m2 of that mesh face.
totalRadiation is radiationResult for each point [kWh/m2] * area of the face [m2] so it is in [kWh]
The image below shows how you can regenerate the totalRadiation by multiplying radiationResult with the area of each face.
Regards, -Mostapha
PS: Also thanks to djordje for correcting my grammar. Highly appreciated! :slight_smile:
History there … :slight_smile:
As Carly Simon’s Anticipation song: “These are the good old days”
I was still in Chicago at that time. :slight_smile:
I think we should leave the old topics with no reply untouched. When we change the category they show up on the top. I don’t know why. :thinking:
Mostapha is there a link to that old picture it takes me to ning.com.
Thank you
Look at the original discussion here.
