Hello community
I 'm trying to understand the chapter of HVAC systems in honeybee. And I have a doubt
How can I set a system with mechanical air unconditioned without heat recovery like this: https://www.siberzone.es/Media/Uploads/dlm_uploads/siber-ficha-tecnica-vmc-amc-hirec-1.pdf
Then the air unconditioned get into the room and the room have a traditional heat bump for cooling and heating (1x1)
I think that the best way is this setting:
I set the heating/cooling supply air temp to 0 and 50, so the cooling and heating for the mechanical ventilation doesnt start.
I not very sure about this solution. Any idea? I suspect that Eplus only let create air handling unit…
Best regards!
