@chris I’m getting the same error when loading my intersected room breps into the HB Room component. Any suggestions on what the error may be?
I have remodelled all of the geometries as boxes in rhino using the box command. They are as simple as can be, but they still spit out the error
I moved this to a new topic since this is definitely a different type of error than was being discussed in that topic.
With this said, there’s not enough info here to provide a helpful answer. We would at least need to know the full error message if not a traceback from the report output.
I think we solved this issue in another thread…
