Hello everybody. I request, if it’s possible, some little suggestion reguarding the mesh settings in a 2d case. I understand this part is more related to openFoam, but i found myself not so able to transport OF scripts inside butterfly.
Anyway the case i set up works fine in the Y and X direction, but diverge in the -X (f course i change the inlet and outlet boundaries in every cases). Moreover, increasing the velocities to 15 m/s makes every direction cases to diverge.
I understand this is caused by a poor meshing, but i’m not able to understand how to fix the problem. What i tried until now is to increase the level of the refinement region to 3 and decrease the cell size to {1;1;1}, but the series still diverge.
I upload the GH file (i ask sorry for the mess inside).
bambooCFDtest.gh (471.5 KB)
EDIT: i just found one of the problem was the snap function of snappyhexmesh off. Now it supports high velocities. Anyway suggestions are still very welcomed
