Hi
Although, I’ve downloaded the last version of butterfly which connects to openFOAM 1706, I still have some old components that cause some errors.The below picture depicts the problem.I just copied the meshparams component from one of the Mostafa’s examples and it worked.
Thanks for your recommendations.
Ehsan.
This issue was fixed (gradXYZ input has no type hint in Food4Rhino installer).
Update BF, use Butterfly BF:BF Component then, close & open rhino.
best,
Omid.
Hi
I just updated the BF but it dosen’t work correctly. As I mentioned in: Got error while updating butterfly
Thanks
@OmidmRashidi is correct. Can you restart Rhino and Grasshopper and try again. There is a chance that Grasshopper is still loading the old components.
