Hi there!
I’m struggling to get a microclimate map in my model.
It worked just fine until i modified the EPW file with Dragonfly, to get a more realistic simulation.
The main issue is that my “honeybee_microclimate map analysis” can’t find several surface temperature in the EP results, but reading those result with the “Honeybee_Read EP Surface result” component i do find all the temperatures!
Even the “Solve adjacencies” component stopped working.
Also, i can’t get my surfaces colored with “Honeybee_Color surfaces by EP results” since the dragonfly implementation. I’ll attach the google drive link
Any ideas of the solution? thank you
