Microclimate map - should ground zone be included for mass intersection?
Hi Chris and Mostapha,
The attached file is a workflow to calculate outdoor thermal comfort at 2m height using UTCI, following your workflow for microclimate mapping (http://hydrashare.github.io/hydra/viewer?owner=chriswmackey&for…).
In your workflow, the ground zone is directly used for solving adjacency with all the building mass. However, it was not used to intersect with the building mass before this step. I wonder if it is appropriate.
In my workflow, the ground zone is included, with all building mass, for intersecting and solving adjacency, and now the top surface of the ground zone is identified as a roof surface.
Is this procedure correct or necessary?
Thank you very much!
typology_v036.gh (684 KB)
It seems I also go the following severe errors, and I can’t figure out why…
Advice is greatly appreciated!
Program Version,EnergyPlus, Version 8.4.0-832e4bb9cb, YMD=2016.01.23 21:02,IDD_Version 8.4.0
************* IDF Context for following error/warning message:
************* Note – lines truncated at 300 characters, if necessary…
************* 160 ScheduleTypeLimits,
************* indicated Name=ANY NUMBER
************* Only last 2 lines before error line shown…
************* 161 ANY NUMBER, !- name
************* 162 ScheduleTypeLimits, !-
** ** Severe ** IP: IDF line~162 Invalid Number in Numeric Field#1 (Lower Limit Value), value=SCHEDULETYPELIMITS, in SCHEDULETYPELIMITS=ANY NUMBER**
** ************* IDF Context for following error/warning message:
************* 258 ScheduleTypeLimits,
************* indicated Name=ANY NUMBER**
** ************* Only last 2 lines before error line shown…
************* 259 ANY NUMBER, !- name**
** ************* 260 ScheduleTypeLimits, !-**
** Severe ** IP: IDF line~260 Invalid Number in Numeric Field#1 (Lower Limit Value), value=SCHEDULETYPELIMITS, in SCHEDULETYPELIMITS=ANY NUMBER
** Warning ** IP: Note – Some missing fields have been filled with defaults. See the audit output file for details.
** Severe ** IP: Possible incorrect IDD File
** ~~~ ** IDD Version:“IDD_Version 8.4.0”
** ~~~ ** Version in IDF=“8.4.0” not the same as expected=“8.4”
** ~~~ ** Possible Invalid Numerics or other problems
** Fatal ** IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination.
…Summary of Errors that led to program termination:
… Reference severe error count=3
… Last severe error=IP: Possible incorrect IDD File
************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
************* EnergyPlus Terminated–Fatal Error Detected. 1 Warning; 3 Severe Errors; Elapsed Time=00hr 00min 0.48sec
Seems this is the problematic text in the IDF file:
Sorry to reopen this post, but I have the same question !
What you finally did @Grasshope ?
Charles C.
