Mismatch between sensor grid count and number of UTCI/MRT result rows
I’m running an outdoor comfort study (UTCI + MRT) on a sensor grid, and I’m getting a row-count mismatch I can’t explain:
  • My sensor grid shows one number of points in Grasshopper (686)
  • My exported UTCI results have a different (larger) number of rows (1541)
  • My MRT results differ from UTCI by a few rows as well slightly (1533 , 1541)
The grid size setting was the same for the run, so I’d expect the number of result rows to match the number of sensor points, but they don’t.
Questions:
  1. What could cause the number of exported result rows to differ from the number of sensor grid points?
  2. Why might UTCI and MRT outputs from the same run have a slightly different row count?
I’ve attached screenshots of the relevant components. Thanks in advance!
Hi @Maedeh_Mohit,
Thank you for posting your question. Unless you can share a sample model to recreate the issue, it is unlikely that anyone can help you with this question.
