Missing text in the _HB View from Viewport components code
Dear @chris and @mostapha,
I noticed that in the _HB View from Viewport component the Options Planisphere [stereographic] projection (s) is missed in the code
I tried to manually edit the code, but the result is not correct
Thanks and best regards
Thanks for reporting this, @LaFleur . This must have been an oversight on my part. I’ll push a fix shortly.
I just merged a fix:
Thanks again for reporting!
Hallo @chris,
I think there is still something wrong, you also notice it from the size of the image.
This is the result,
instead this should be the result:
The second Image would be generated with Honeybee-Legacy, thanks the code adjustment from @mikkel, explained in this post,
Hi @LaFleur,
If you set workers to 1 it should work for now. When the planisphere view is split by the workers it does so incorrectly at the moment. That’s why your image is wrong.
Hey @LaFleur ,
@mikkel was able to figure out a fix and I just merged it into the codebase:
You should be able to get the fix with the LB Versioner in an hour or so. After that, you’ll get correctly-sized planisphere images out of the View-based recipe no matter how many workers you use.
Thanks @chris and @mikkel, now works perfectly!!
