i have a project which requires to simulate about 90 buildings at the same time. If i follow the rendering method shown in the photo, my computer will very lag. Therefore, how do i set up an extra command so that only the selected building will be rendered or limiting the number of objects which are required to render, thanks.
Hi @yinlong ,
Have you tried using the Dragonfly Visualize components?
Those can help you get a rough preview of the Model quickly (before it is translated to Honeybee). If you really need something rendered in detail, I recommend making dragonfly models with just the buildings you want to visualize and then you can translate those to Honeybee.
