How would you model a body of water in a Dragonfly model? There seems to be only settings for grass and pavement for ground cover.
Hi mlandis4!
It’s simple: you can’t. Dragonfly (among other things) uses the UWG engine (https://github.com/ladybug-tools/uwg) which is based on a 1-D urban canyon model. You have a couple of choices:
- Use another piece of software that can model the urban climate at city/region level. If it is the microclimate you want look for the free version of envi-met (for academic purposes).
- Alternatively you can use butterfly and model the water surface with a reasonable surface temperature (ideally this should change in an hourly basis). Check this paper for an indicated workflow: http://www.ibpsa.org/proceedings/BS2017/BS2017_260.pdf
- Place a datalogger near the desired water body and measure the air temperature and RH on the spot. Place a second datalogger inside the city and compare results. This is the safest approach because you can then create an empirical model from observations.
Hope this helps
Aris
Thank you both for the responses. It looks like, for now, I will be moving on to Envi-met.
Hello, I’m startinf with Dragonfly and I was wondering too how to approach to areas nearby lakes, rivers or even on the coast. I’ve looked into the topic @devang quoted, and found something interesting but not decisive. Are there any news about this?
