How would I model an airloop with a water-cooled DX cooling coil using GH/ironbug?
Thank You,
Thank You,
Hi @Arhaan do you have a sample file that has what you want to do in OpenStudio or EnergyPlus?
Hi @MingboPeng,
I unfortunately do not have a sample open studio file.
I need to build a 100% OA DOAS unit with a water-cooled DX coil. It will probably come under “AirloopHVAC Unitary System” in open studio. This unitary system is then connected to a CW loop.
Thank You,
Hi @Arhaan, if you have an idea of modeling it with the Unitary System, you can do it with Ironbug as well. Please let me know if you want to recreate a system with Ironbug when you have a working sample in OpenStudio or EnergyPlus.
Yes, I will be able to model the unitary system in Open Studio so I will attempt to recreate it in Ironbug. What are the steps to customizing a unitary system in Ironbug?
