Modelling a park on slope for ENVI MET analysis in DF-legacy
Hi everyone, hope you are healthy,
I am working on a landscape project, and I want to investigate the influence of green corridors/ water walls on local thermal comfort, and I am a beginner to ENVI-MET and Dragonfly.
but the park I’m working on, is located on a sloped terrain, which makes its ENVI-MET modeling challenging for me as an amateur.
does anyone have a tip on how can I model this area? should I flatten the whole region? are there any simplification methods?
Thank you in advance for your tips and suggestions.
Hi @Nimafo,
You could model the elevation using the “DEM” (try to merge all surfaces in a single mesh using a native component of GH). Whilst the different surface material (pavements, alsphalt and so on) are “soil” objects on World XY plane.
If you have problem I can have a test.
Antonello
Hi @Nimafo,
Here is an example file:
Park.gh (403.9 KB)
Antonello
P.S. I have updated the component to run the simulation with GH.
Awesome,
Thank you for your help,
@Nimafo Can you please share an Example file as I’m facing some issues in adding Fountain in the script and Visualizing in Grasshopper.
I am currently experiencing the same problem. Can I import my sloped topography into ENVI-met using Grasshopper? I do not need to differentiate the surface materials; I only require the topography curves.
