Morpho - Honeybee Two-Way Coupling
Hello everyone,
I am working on a building and microclimate simulation using Honeybee and Morpho and would like to couple the results to analyze their interactions. However, I have encountered a challenge: Morpho does not seem to have an option for incorporating heat fluxes from buildings.
I have seen similar approaches implemented on other platforms, but with ENVI-met, I am unsure whether it is possible to use EnergyPlus results as inputs to Morpho to enable dynamic data exchange between the two platforms.
Has anyone successfully integrated EnergyPlus results into Morpho or found a way to facilitate a two-way interaction between these tools? I would greatly appreciate any insights or suggestions.
Thanks in advance!
@chris @AntonelloDiNunzio
